XJ&CHZ4ME
- Unionville, MO
that HD kit is nice and if you order during the month of April Brian will throw in one of his "Many Swimsuits of Brian" calendars...sure to make the best of shops look bad.
So...its nude pics?April fools, everyone knows I don't wear swimsuits....
I threw 4 rims and tires , the old leafs and 2 vises in back. It dropped an 1". I think the problem at the moment is the shackle angle. Its pretty much perfectly vertical. I think the shackle is holding it up. Im gonna order the HDoffroad no lift shackle relocation.
I cant remember the last time I used a spring compressor to get out coils...like Nate said, undo the control arms and helps to also undo the draglink from the pitman arm, it will give ya all kinds of droop to work with.
you think im gonna be able to swap from coils without a spring compressor? Just get the front end up and stuff one side best I can to droop the other side...
I hear ya. Whenever ive done them on cars I ran a chain threw them and attached them in some way to stop any sudden ejection. Spring in the face can ruin a dayIm not a fan of the spring compressor. scary as can be to me. i have just dropped the track bar and used a pry bar every time i done them.
