_MURDERED OUT_
- Hernando, MS
oh yeah, baby ass yota joints.....
_MURDERED OUT_ said:Sierra Drifter:
on your buildup page, one of the last posts has a pic of some shock mounts...
Where did you buy those?? I need a set of those! I have to install my shocks after flipping my rear leafs and stretching the wheelbase. Im making a frame cross bar to mount the top of the shocks to and will be needing to make some lower weld on mounts.
Sierra Drifter said:JKS makes those shock mounts, but they are overpriced at $60.
http://store.jksmfg.com/merchant2/merchant.mvc?Screen=FAB_922&Store_Code=JKS01&Category_Code=FABParts
You can make them, buy one leaf spring perch, cut it in half, and drill a hole for the shock bolt.
:bawl: waaaaaa i wish my 2004 dodge ram 2500 cummins turbo diesel had a real drive shaft :bawl::tears: lol.88rockxj said:thats the way real drive shafts are made, look under an 80s toyota.
_MURDERED OUT_ said:Yeah i think they designed it to handle the torque of the cummins diesel. Im assuming maybe the 241 in the 2500-3500 Dodges are of the same design other than the lower planetary gear set...
Dodge used the 241D (3 planetary) and 241HD (6 planetary) in the 2500 and 3500 up until 2003 when they switched to the 3rd gen body style, and a common rail diesel, and that is when they put in the 271. they are all 2.72:1 cases_MURDERED OUT_ said:i thought they used 241's in the heavy duty dodges. They used them in some of the 1500's i think....
oh and im about to order my yokes for my rubi case. Im getting the tom woods rear flange and a 1310 u joint yoke from High Angle Driveline.
RCP Phx said:Why not just get both yokes,I run identical fr/rr shafts on mine.
_MURDERED OUT_ said:well, i cant run a cv front shaft like most of you do. I have way too much lift and the stock cv bottoms out way before reaching the front pinion yoke, so i run a traditional 2 u joint front shaft.
TNT said:Your front shaft angles must really suck. Call Jesse at High Angle Driveline and put some real shafts in your rig.
If you are going to build it do it right...:twak:
http://highangledriveline.com/
Thats not the same as a NV241OR.......winkosmosis said:Is something like this a good alternative to getting a SYE for a 231?
Edit: Wait.. According to this the NP241 has a slip yoke. I thought they didn't use one for the Rubicon... Jeep upgraded to a stronger transfercase with 4:1 etc, but kept the slip yoke?? Typical
!!!1
