woodkrawler
- Charlotte, NC
I aquired a TJ rubicon 44 front axle housing from a friend that I plan to use in my MJ project. It's just a housing so I have to fill it with gears, locker, shafts, etc...
I'm having a brain fart and need a little help. Since I'm not running the Rubi air locker will any standard low pinion dana 44 carrier and ring and pinion work? I know to retain the Rubi air locker "thick" gears have to be used.
I plan to buy an Auburn ECTED for it with std cut 4.88s and rebuild kit? Any problems with this?
