XJ_Jeeper01
- Avondale, AZ
yea i can get a pic of that. i forgot to take some pics towards the end of the build, it was getting late and i was tired. the passenger side upper mount is still on. i may cut it off not sure yet. i'll see when i measure for new bumpstops and for some limit straps. i do need to trim the bolts some on the upper axle mount.az4wheeler2002 said:acouple of question, can you get a pic of the front with the upper control arm installed, believe it or not, alot of people install the upper arm incorrectly, also did you cut off the excess bolt for the upper axleside mount, and did you leave the passengerside upper axleside mount on the axle or did you grind it off?
I'm not bitchin I think you did an excellent job, I wouldn't worry about the welding, it coulda/shoulda been done better, but it's done and overwith now, I would just like to see a complete build up, b/c its not very often where someone does a build up and goes over everything
