At this point I would re do the noid light test and wiggle the light to see if the connection is loose, and swap a pair of injectors. Sometimes these things change while you are running tests, intermittent. Could be a problem with the end connector not making good contact all the time. Or it could be a defective brand new injector that happened to end up in the same cylinder (highly improbable, 1 in 6 chance) but once we eliminate the possible we must evaluate and assume the impossible is possible and happening!
Also try wiggle the injector wires, wiring harness to see if the problem comes and goes, like an intermittent ground in the harness, or ...
