2stix
- fallbrook Ca.
so i took the pump out and inspected it. hose from pump to tube was good but i did tighten it just a hair more. pick up screen was clean and in good condition. all wire connections seemed good but i took them off, crimped them a little tighter and re attached them. unscrewed the small ground wire and cleaned its surface, then re tightened it. even took 39psi air and applied it to the feed line end and it seemed to hold it. so i re installed everything and tested it. it now holds pressure after shut down. still have 29 psi while running, but i think that is acceptable. not sure what i did to make it hold pressure though.
now i am going to have to start another thread about the low idle as this did nothing to help that. i did re test the CPS and found i was only getting .37 volts AC. so i took a pry bar and rested it on the metal tab and tapped it with a small hammer to see if it will bend it slightly toward the flex plate. it must have worked as i now am getting 1.51 volts AC. i know that is way over spec, but the CPS is not interfering with the flex plate and it starts real nice. idles good for a good 10 seconds, then starts going lower and lower to about as low as it will go before it dies. (maybe 200rpm) then just stays there. it seems like the ECU is adjusting the timing to lower the idle for some reason. anyhow, i will get into all this mess in another thread. atleast i have fixed the "loss of fuel pressure" deal.
thanks guys.
thanks guys.
