- MilkyWay Galaxy
I cleaned up the (+) connections from the battery (+) to the starter relay (+) post, and all the in line fuse linked wire connections on the (+) post on the starter relay, and cleaned up the grounds at the oil dip stick.
I retested the ECU-CPS wiring and the two leads versus the battery negative post do read 5.6 Megohms, but read 9.6K ohms pin to pin in the harness. That is the norm it seems. So in a rush a few days ago, I got the 5.6 Meg Ohms thinking it was open (thinking I should be getting 9.6K ohms), when in fact I may have moved my meter ground to the battery due to back probing issues, not being able to get and keep good contact. So there may have been nothing wrong that day with the CPS harness connections for all I know.
I have just replaced all 5 under the hood relays, and cleaned the contacts. It never failed to start in all the tests today, even when I forgot to reconnect some vacuum lines after recalibrating the TPS (it ran up 2500 rpm) it still started. I ran a voltage drop test earlier today before cleaning the positive wire connections to the starter relay post, and I got a 10.6 V minimum there during cranking with the E-cooling fan on IIRC. I will retest the voltage drops again in a day or so. For now I need to take of other round to its. I have run repeated stall tests, and even lowered the idle to about 500 rpm in D or R, with AC and lights on, and it will not stall, even at 500 rpm.
I need to adjust the TB to correct uncle Bobs changes and do one last TPS calibration, and see where I am next. I also need to check the CTS and the O2 sensor to see if the O2 sensor is making me run too lean and messing with IAC control in the process.
