Lots of new data. The numbers on the non running 89 changed and it ran today, even restarted. It was warm and humid today.
First off the
working 87 Wagoneer, that
has no start or run problems:
Note: Unless otherwise noted, voltages were at idle!
87 Jeep:
Power off:
CPS connected to harness: 238 ohms
Bare CPS: 244 ohms
CPS harness wires loose pin to pin: 9.29 K ohms
Power on (engine off):
CPS harness wires loose pin to pin: 0.00 V AC, 0.00 V-AC
Power on, Cranking, engine not running:
CPS disconnected from Harness while cranking: .28 V AC
Engine running, CPS connected (back probed):
At first I was getting .44 V AC at idle and 1.0 V AC at 2500 RPM first 5 minutes. Later I noticed that back probing was giving me trouble, and checked the numbers again, Once I got solid contact back probing I got 1.2 V AC at idle and 2.8 V AC at 2500 RPM, but with poor contact back probing I was seeing .44 volts AC. So my good reading once I got good contact was 1.2 to 2.8 V AC on the CPS with running engine. So that is now confirmed!
So the contacts are little iffy on the back probing. Technique seems to be an issue. I need to get some of those wire piecing clips Tiny pin pierces the insulation that make this a lot easier.
ICM connection data 87:
Power on, Engine off:
Left lone yellow wire: 5 V DC
Next yellow wire, left on Conn #2: 12 V DC
Black middle wire: 0.00 V
Green right wire: 0.2 V DC
Power on, Engine running:
Left lone yellow wire: .57 V DC, .96 V AC
Next yellow wire, left on Conn #2: 14 V DC, .131 V AC
Black middle wire: 0.06 V AC, .03 V DC
Green right wire: 14 V DC, wandering AC signal, unstable signal Note the 89 had 5 V AC here!)
89 Jeep (the one with nomad gremlins on board!
Today I got totally different readings!!!!! And it started today!!! And ran!!! And now I can not make it die unless I turn it off the old fashioned way!
Power off:
Bare CPS: 352 ohms (this is a new CPS)
CPS harness wires loose pin to pin: 9.33 K ohms (was 5 meg ohms last time!)
1.5 V AC at Idle
2.7 V AC at 2500 RPM
TPS voltage at idle:
.85 V
ICM connection data:
Green right wire: .2 V DC
Next yellow wire, left on Conn #2: 14 V DC, .13 AC
Black middle wire: 0.3 V DC, .16 V AC
Green right wire: 12.5 V DC, 5 V AC!!!
89 engine RPM was back down about 200 rpm on average versus last 2-3 weeks. Maybe dirty loose weather back connectors, IAC connectors, or who knows what, but Idle is not as stable as it was last week, and is down about 200 rpm net.
