removing wiper arm
lift the arm away from the glass as far as it will go. bout a 1/2 inch. Use a screwdriver to push away the clip you see from the arm itself. It won't come out only moves a little bit now you arm should be sitting away from the windshield maybe 1/4 - 1/2 inch. use screwdriver ( flathead ) gently underneath the arm where the shaft comes out being careful not to score the shaft, and IT SHOULD POP OFF !!!
