Ok well I was just going to edit my last post and put more info in it butttt I can't do that 45 minutes after I make the post i guess so heres a little more info on this...
I actually did some work on this little guy
I've been doing alot of this lately
Grinding the rust off of everything so maybe I can control the decay of my jeep someday, It seems this winter was the worst and it isn't even a DD so I don't get how the rust can be that bad but oh it was. But this got a good wire wheel bath, just like the other misc parts and repainted
Blam sh*t's fresh now
Also took the time to really finish up my rocker project..
Like I said I'm using "Eric Xj's" technique and will be using 2x6x.180 for the actual rocker, and 2.5x2.5 angle steel on the seam with the floor and the rocker use to meet to add some strength and also some meat seeing how this is now lower then my rocker now it needs to be able to deal with a rock impact or whatever, then some 3" flat stock to tie the rocker into the angle steel, and lastly some 2x2x3/16 to go from the angle to my frame stiffeners to really tie everything in, it should stiffen the body up perfectly
After a quick test fit
Time to start burning it home
Here's with the flat stock added, I still have to add in the 2x2 but this is pretty much the finished product, looking at it now that it's done I'm probably going to have to cut about 3" off my doors so they fit nicely again, but I think it's VERY worth it, only down side is since my jeep does sit a little high it's kind of a PITA to get in and out of smoothly, but hey jeeps are ment to be awkward
And threw some color on it looks pretty for now....
And if anyone was wondering this is the welder I'm rocking
