rear sway b ar
Ok guys I was wondering what will happin if I take off my rear sway bar as far as handeling is concerned
nothing. absolutely nothing. rid yourself of it!
But save the mounting brackets. They can be re-used as bar pin eliminators for the rear shocks.
doing that does not mount the shock corectly and you can damage the shock
you will notice nothin, i removed the rear sway bar on bith my xjs and didnt notice a thing, some xjs even came from the factory without one
Mine shocks have been that way (BPE's) for 3 years. No problems. Actually a better ride. Shocks spin and make up for the different angle.
No funky rusted out bolts and/or dumb *** bar pins.
Rear sway bar? What's that?
they are like those twist-tie wires that hold new toys to their packaging, because you have to remove them before you can play with your toy.
With the rear sway bar the only thing I noticed was Hwy speeds changing lanes you get some sway at higher speeds. But you get used to it pretty quick and I don't even notice it anymore. YOu just have to slightly... very slightly change your driving style.
Only time I noticed a difference was while towing. I currently have put them back on both of my rigs, because I tow and I'm not the only driver of them. . Although currently they are stock.
