bert01xj
- souderton,pa
if you check you local chapter you might find one cheap or free like i did.
I did some searching and found the part numbers (from a 2000 parts catalog) to order the oem hitch and its mounting hardware brand new. In case someone wanted the info here it is.
2" receiver - 82204709
1.25" receiver - 82202852
I'm afraid to ask, but what prices go along with these hitches?
yes, but a rear receiver hitch makes a rather economical and sturdy recovery point, and the more bolts you use for that the better... recovering only the receiver hitch, bolts, nutstrips, and bottoms of the frame rails would suck :jester:by the time you get to a weight where that matters, you are way way beyond the safe towing capacity for an XJ
I used a Holly wiring harness that plugged into the stock wiring as well. It's got a T-shaped electronics box (has some diodes, resistors, and power transistors in it, looked into building my own but then got lazy and just bought one) with a connector on each side that plugs between two of the stock wiring harness connectors. You just unplug the harness, plug in the trailer wiring harness, then plug the connector you unplugged back into the other side of the trailer wiring harness / box.I 'm not sure how it varies by year, but I think most XJ's have a plug behind the trim behind the spare tire, to which an adapter can be attached. All three of mine have come with the wiring already in, so I never had to dig too deep.
I have a Hidden Hitch on both of my XJ's, only the receiver section sits below the bumper. Not sure what they are going for new nowadays, but you might be able to find one used.
The U-haul hitches might be nice, but I recommend that if you get one you install it yourself. If you intend ever to take the hitch off again, avoid the carriage bolts with square washers that they use to install them, and get the nut strips. Both my 95 and 99 came with U-haul hitches (small receiver, which is why I took them out), and they were a bear to remove. If they loosen up at all, they're impossible to tighten, too. In addition, the 99 had been installed by someone with no brains at all, who tore holes in the frame for access, and who pried the right hand nut strip up out of the way in order to install the bolts. It was a real ****-up, and required a good bit of torch work to remove. I think there are still some pieces rolling around in there.
