Well thought I would provide a status report / my experience on this.
Got the swap done last Saturday. And in general it went well. I knew I should have gotten new U-Bolts but hoped with 2-3 weeks of PBlaster that I could reuse them since I am expecting to have to replace the springs in the fall. almost all the bolts snapped off. Also The new axle had rust and other build up in the yoke requiring me to swap over the yoke from the 27-splie axle and get new strap kit.
Also don't forget the axle seals... I thought the seals where on the diff side of the tube and not the outside. So after I put in the new bearings I forgot to put the seals in until I was leaking fluid out the axle.
My drums were fairly shot. One side was down to metal while the other side still looked like it had a good amount of life left.
The Bad Drum:
The other side:
So going to anything would be an improvement on the braking.
Axle came out with relative ease. Also at this time I would like to say how much I hate brake lines. I also replaced all the soft lines with Toxic SS brake lines so removal of the soft line from the hardline was always a challenge. I ended up having to cut, flair, and union the rear line.
Axle came out:
Then there was the problem with the e-brake lines. I got the liberty lines as a few write-ups made it sound like these would be a drop in replacement, the ZJ lines are to short? and using the XJ lines you have to mod the brake side of the connector. I decided to try to hack up my new liberty lines to match what XJ mounts there are.
I measured and mocked up the line. cut off the ferrule on the brake line and slid out the cable. I then cut out the section that I needed from the housing. cleaned up both ends and used shrink tube to seal and hold the sections together. 2 layers, then two helical springs wraping with a 3rd layer of shrink wrap. Cut the wire so I would have the correct amount of wire from the mount to the new ferrule. Did this for both sides.
The new brake cables:
This will allow for the proper spring preloading on the e-brake side and will connect to the OEM mounting locations on the XJ.
I have yet to install these as I have ran out of time. They will be installed sometime this weekend.
Also installed a new proportional valve from the ZJ. Using 2 qts of brake fluid to flush and bleed the system out after the replacement of the lines the Jeep feels new... with the brakes at least. Pedal movement is now no longer to the floor. If you really stomp on the brakes it sounds like the tires might be able to lock up now. Hope that once I get the new cables in the e-bake will now work.
Thanks for the help everyone has provided.
