The Lure Washer
- Bristol, CT
i have a 1990 cherokee on 4.5in lift with 33's. So some how my rear axle shifted backward on the driver side causing my drive shaft to put out of the transfer case. The t case is a 231 and rear axle is a D35. When i crawled under the truck i noticed that the shock was busted at the mount. Luckily the bar pin just came off the bolts. Will that cause the axle to shift back like that? The leaves are still sitting in the perches. Also can i just push the yoke back into the transfer case? Luckily for me i have tomorrow off but this is my daily driver.
