MisterFubar
- Home
lowrange2 said:how slow is slow? Is gunna take way more than .003. The largest diameter of the TRE shank is .755 and the smallest is .688. So that means that I would have to remove .0335" of material.
Also this is the Snap-On Repairmans Reamer Stock No. R121 States: USed for enlarging holes from .5" to 1" - For use in any material. Not that that means anything but I thought maybe it was meant to move more metal.
I chucked an R121 up in a cordless drill, and went to town on my pitman arm, while keeping it lubed with a can of WD-40. I know it wasn't the right way to do it, but it worked and only took about 10 minutes of short slow bursts with the reamer.
I also used the same method on a set of D44 knuckles.
