- Bakersfield, CA
Wondering what thoughts you guys with experience have on this situation. My buggy is an '89 Renix automatic, but it has a '98 HO motor with only 60k on the motor. The buggy won't get much mileage put on it, probably the equivalent of a couple thousand miles a year. I'd like to get more power out of it, mostly mid-range, but don't have much money to spend doing it. It already has a good (I think) Gibson header and 2.5" exhaust. The Renix throttle body is adapted to the HO intake. It's not street legal or registered, so no smog.
Since the motor is pretty fresh, only 60k, I'm thinking of just making it a 4.5L. Replace the crank and rods, new rings and bearings, use the same pistons, and put a better cam in it. I'd use the 24lb Ford injectors, I have a couple left over from the XJ stroker so only need 4 more, and probably a larger throttle body. I like the higher compression ratio, and don't mind running premium for as little as it will get used.
What thoughts and recommendations do you guys have? I haven't looked into this for awhile, my XJ stoker is a few years old now. What's the latest cam that everyone likes?
