You left out the obvious...10" body lift, rockwells, 12 link rear, Ferrari v-12 (had to move the firewall back a bit) Atlas XXVII 9.5 tcase, titanium skid plates, carbon fiber rims
d10shun said:10" body lift, rockwells, 12 link rear, Ferrari v-12 (had to move the firewall back a bit) Atlas XXVII 9.5 tcase, titanium skid plates, carbon fiber rims
The bumper is 2 3/8" 0.D. 1/4" wall tube, and two 1/4" steel brackets that mount on the inside of the frame rail using the front two factory bumper mount holes. I don't have any pics, but the process was super simple. I took off the factory bumper first and looked things over. I wanted a tube bumper that hugged tight along the bottom of the grille. First I measured across the front, total distance, then I cut the tube to length. Next, I found the center (it needs to be bent a tiny bit to hug the front form) I cut a slit with a disc 1/2 way around the tube, enough to leave a small gap. Then hold the tube and bang the other end of the tube against the ground until it bends on the slit creating the proper bend. I mocked it up on the Jeep, by holding it up in place for fit (2 people is a big help). The brackets are just 5 1/4" high x 4" rectangles, with a circle cut out where the tube rests. Two holes drilled in the brackets where the two front bumper holes are. I bolted the brackets in place, rested the tube in place. Made sure it was even and centered, then tacked it in place. Removed the bumper, welded the slit shut, welded the brackets. Spray can black - $23 total. I'll be adding wrap around ends sometime, it gets the job done for now. I can send pics later.scottsxj said:hey barillms, do you have any closer shots of that bumper. It looks pretty slick from what i can see. Oh and nice rig
scott
i have pics of my heep in that exact spot, in that exact pose =)d10shun said:10" body lift, rockwells, 12 link rear, Ferrari v-12 (had to move the firewall back a bit) Atlas XXVII 9.5 tcase, titanium skid plates, carbon fiber rims
what trail is that first pic?RobCherokeeXJ89 said:Here's A few pics of my Rig
Specs: 3" Lift, 32" MTR's, Lil Trimming, Open 4.10's , Fully Skidded,ARB Front, C4x4 Rear
<IMG SRC="http://memimage.cardomain.net/member_images/5/web/701000-701999/701031_38_full.jpg">
<IMG SRC="http://memimage.cardomain.net/member_images/5/web/701000-701999/701031_17_full.jpg"
<IMG SRC="http://memimage.cardomain.net/member_images/5/web/701000-701999/701031_6.jpg"
My Website: http://www.cardomain.com/memberpage/701031/1
Green is the only way to go. Heres mine with new wheels and tires courtisy of sidriptideJeepsterboy101 said:always been a sucker for green.
