RC flex arm lengths?
Thanks Jason. You say "around", is that a guess or fact? Can you get the exact specs? I really need 14.75" on the uppers to get my axle at the right wheelbase and stop my drag link from hitting the sway bar when turning to the right. The axle is too far forward with stock uppers and your flex lowers. I can't adjust the lowers to change the wheelbase cuz it messes up my pinion angle. I wouldn't want to order a set and find out they are too long.
edit: never mind Jason, i figured that you were talking about both uppers and lowers and I was only askin about the uppers so 14.5" for the uppers (if that's right) will work out perfectly. Thanks!
