88-cherokee
- sac,ca
i have a 96 xj 4x4 auto 4.0 now i understand there's other forums open on this topic but my issue might be alittle different.
So my issue is at an idle i have a misfire on cylinder 1 and 1 only, ive pulled the header and welded the leaks cleaned the intake and tb. now heres a list of parts ive changed iac, tps, upstream 02 sen (cap ,rotor ,plugs and wires twice ). ive swapped around injectors, i even got a noid light to test the injector wires and everything checks out good but im continuing to have the misfire on cyl 1 only in not trying to hasta but im seriously not understanding why in having this issue
