- Southern Maryland
does anybody know if the aluminum stick radiator probes read actual temperature or if they are calibrated to guess the coolant temperature through the radiator fins? like, if I wave one of them around in the air will it read air temperature or be off by ~50 degrees or whatever?
I'm thinking through options for a second electrical fan, and the FSM says the mechanical fan is designed to lock up at 190f air temperature on the face spring, so that is what I'm trying to copy
