- Burbank
Hello,
I've been looking into lift kits for my 01 XJ and am a bit torn between a couple of them and would love some opinions/advice/suggestions from folks. Thanks in advance for any responses!
I'm not planning on doing anything too hard-core in my XJ, but I would like to have a vehicle that is more capable than a stock one. I originally wanted to get the OME 2.5" suspension system, but then I started thinking about the RE 4.5" kit. My thinking was "If I'm going to lift it, might as well get a 'medium' lift done once instead of a 'small' lift, then a 'medium' one years later. I'm not planning on running 33" tires because I'd have to re-gear my axles which isn't in the budget, so I'm having a difficult time justifying the 4.5" kit.
I've heard that both kits are quite good, they both come with everything needed to get it installed, and are approximately the same cost. Since I'm only planning on running 31" tires, I can't see how I'll be able to take advantage of the RE kit - unless it has drastically more flex than the OME kit.
Which kit would you go with, and why?
