Keekleberrys
- Issaquah
I did run a search before posting but there are so many threads out there about sliders that I was not able to find an answer.
I have my AJ's rails painted and ready to mount. My question is regarding the rear leaf spring hanger. I am assuming that it is not supposed to mount through the pre-drilled hole, as I could not make it line up on either side, and still line up with the pinch seam.
Secondary question. The pinch seam on the passenger's side is not uniform like that on the drivers side, there is extra material folded over and overlapping, such that the holes towards the front of the rig are very close to the edge of the seam. Should I grind the seam flush or just grind a portion out of the seam near the main leg of the slider to get it to clear a little bit higher.
