ZmOz said:
043500, you have still yet to give any reason for propane. What would that be? If you had a carb, propane would be better. If propane was alot cheaper than gas, propane would be better. If you had an engine built for propane, propane would be better. You don't have any of those things. Please tell me why you would want to spend alot of money just to run propane? It doesn't have a single advantage.
For me it does...how many reasons you want? I have many.
#1) My rig may sit for weeks at a time withough even being started. Gasoline has a tendency to build moisture as well as it will go bad. Propane does neither.
#2) I run in an area where rollovers are fairly common...I've seen gas spilled out numerous times. Not yet seen any issues (like fires or explosions) BUT I'll never spill a drop of propane no matter how steep the angle nor in a rollover. And yes I know about fuel cells...not too many cheap ones that are DOT legal. And even though this is a trail rig it will be street legal.
#3) There is a "cool factor"...why not run propane.
#4) I think I'm going to do it now just to tick you off. (sorry had to do this)
#5) It's a simpler setup vs a gasoline system as there's not really any parts to malfunction or break (unless purposely done)...and sicne I need a new fuel system anyway from the tank to the throttle body...the price is not even a factor for me.
#6) A propane tank is MUCH less puncture resistant compared to the plastic stock tanks... in the event I get to close to a tree, rock...or again in the event I roll it.
#7) The MJ is light to start with. Since propane tanks can be mounted ANYWHERE in ANY position...I can decide where best to put them for weight distribution...to do this with a gasoline tank and be SAFE I'd spend a lot more coin and might not be DOT legal.
Any more questions? Now...I ask YOU again ZMOZ...Where's the actual numbers on this drastically horrible fuel mileage I'll get? Everyone I've spoekn with...be it affilited with "got propane" or not has not once said anything negative about fuel mileage. And while you are right...the mileage isn't as good as gasoline...it's NOT the aweful mess you are making out to be.
