builder
- Yucca Valley california
Goatman ran thee king of the hammers race last year with a 3 link front and rear.placed extremely well. and i am sure he will run it again this year.
you just need to make sure that you have your mounts welded on properly and they work awsomeGoatman ran thee king of the hammers race last year with a 3 link front and rear.placed extremely well. and i am sure he will run it again this year.
Dude, I'm too f'in POOR to buy the stuff I would like to have so I make the best of what I can afford. Is that clear enough?maybe I'm misreading...
but you'd rather buy a suspension system that isn't gonna work exactly right cuz you'd rather fix it then spend the same if not less and buy something that'll work a ton better...
is that what you said?
to go with johns theme, you might not know the feeling of buying something that will work OK then modifying it so that it works better than the top of the line product off the shelf and is half the price, oh wait, if you modified your jeep Cherokee for performing off road then may be you might know that feeling, the Cherokee is fairly capable, a Rubicon Unlimited is better but a built Cherokee is even better still!maybe I'm misreading...
I am relocating the upper control arm rear mounts. I am considering lengthening the upper control arms and building some custom rear mounts since I can do this cheaply.I know that feeling of building a jeep.
sorry you didn't get the kit you wanted.
what are you doing to make it work like it should?
I have decided to extend the upper control arms and fab up some mounts that will go onto the cross member. This will be the best compromise I can make while not costing me much. I will post up some pics after I get it done.I am relocating the upper control arm rear mounts. I am considering lengthening the upper control arms and building some custom rear mounts since I can do this cheaply.
I was planning to do outboard limit straps but I will look at all options.good job... Might want to think about a center limit strap on the axle to keep the front end from unloading on climbs.
I believe this will be the last mod needed. Too bad I am not rich so I could just buy a system already engineered
