N20Jeep
- J-Ville,FL
decided to change my crossmember mounting. on the last XJ i sleeved the frame rail and through bolted it with 2 1/2" grade 8 bolts per side. it worked ok, but was always a pain to drop down and line back up. so i decided since i was installing stiffeners anyways and that i would have to modify it to fit the stiffeners that i would bolt it up from the bottom instead. so i cut off the outer 1/4" plate (left the inner, because it helps position the crossmember and it doesn't get in the way.) mocked up the stiffeners, marked everything, and drilled.
i drilled 5 holes per side, and welded in 5 1/2x13tpi nuts into the stiffeners per side. as of now i will just be using normal hex grade 8 bolts to secure it. and down the line i may run countersunk bolts. either way shouldn't be an issue since it will all be covered in a UHMV belly so i won't have an issue with hitting the bolt heads on everything.
