spencer elliott
- St. Louis
ok so ive got most of my supplies for this job, but need to know a couple of things first.
does the raptor kit come with a degreaser? i know UPOL sells a degreaser, but does any of it come in the raptor kit? im guessing not from the description of the kit on their website. i ask because ive still got some POR-15's "marine clean" and may try to use that instead of buying something else. only problem is that im not sure if ive got enough. if i do have to buy something then what would be recommended aside from UPOL's degreaser?
my plan is it use a scothbrite pad on the factory surface to remove the clear coat and roughen it up a bit. then to take a wire or crimped wire cup brush to the sections that have rust, and also to remove the rubber undercoating inside the fender wells. after clearcoat, rust, and undercoating is removed to the best of my ability, i will clean it and use Rustoleum Self Etching Primer on all of it. then finish it with the raptor.
does that sound about right? i dont have to remove the factor paint right? just the clear coat...?
any other advise is appreciated.
