Goatman said:Nice job. I still want air bumps in the rear of the XJ one of these days.......
How did you secure the bumps in the mounting cans?
Uglygreenxj said:I ordered the kit from T&J for the front and they simply drilled a hole in the side of the can and tapped it, and installed a set screw with a jam nut. I have heard of the clamp style ones squeezing the bump too much and not allowing the piston to move freely so I assume that is why they changed it to this style. Anyway, I didn't feel that it was enough material to tap so I drilled a hole in the can and welded a flanged nut to the outside of the can and then installed a set screw and jam nut. We'll see how it holds up.
Goatman said:Well, that's what it looked like, but I wondered. How thick is the wall of the bump stop tubing? If the clamp type would squeeze it too much, it seems like a set screw could damage it also. Hmmmm.......
I really wouldn't worry about the set screw, they are made to keep the bump from falling out which is not very likely as it was a real tight fit on mine, had to grease them up good and even hit the inside with a drum sander after welding shrinkage to even get them in, not doing anything towards compression as the lip of the bump is tight against the tubing stopping any movement. Looking really good, may have to change your user name as it is not ugly IMO.Uglygreenxj said:That worried me too. I don't know what the wall thickness is of the bumps. I figured that the guys that are racing are way harder on them than I will be and it's working for them so...... Plus, I wouldn't have had room to build mine with clamps. I had to mount mine a bit higher than most do due to already having pads built on my axle and I didn't want to pull the axle to change it at this stage.
Skullvarian said:I really wouldn't worry about the set screw, they are made to keep the bump from falling out which is not very likely as it was a real tight fit on mine, had to grease them up good and even hit the inside with a drum sander after welding shrinkage to even get them in, not doing anything towards compression as the lip of the bump is tight against the tubing stopping any movement. Looking really good, may have to change your user name as it is not ugly IMO.
Chris
Parker pumper fresh air system, just don't spill any gas near the intake or you will smell it/breathe it for a bit. Ours will have the exhaust coming behind/under the driver doorJump This said:Its important to realize the eddy (sp?) effect our Jeeps have from having a large flat back window area. Without a rear window you will be pulling exhaust fumes thru your rig, open windows or not. You might look into a side exit point for the muffler.
My exhaust exits just about the same point as yours. I don't do much high speed stuff (you guys are all nuts!) but I still pull in fumes just from around my shock towers (inside mounted.)
How are the other Jeepspeed guys dealing with it.....?
Rick
Skullvarian said:Parker pumper fresh air system, just don't spill any gas near the intake or you will smell it/breathe it for a bit. Ours will have the exhaust coming behind/under the driver door
Jump This said:That is what I thaught.
But look at the problem from a hobbiest point of view.
A Parker system isn't cheap and is most effective for dust situations right?
So to solve the pulling in of fumes you need to move the exit point of the exhaust into a 'moving' air flow area. There are certainly many ways of doing that. The pipe can exit below the rear axel, not rock friendly. Or you could have it well above the roof line, completely effective , but I'd bet it would look ugly as sin. Or move it to a side exit point.
You guys try all of those and let me know which one works the best.
Rick
Uglygreenxj said:I was thinking about installing some of the vents in the roof I've seen on some of the Jeepspeeds, I'm just not sure where they're sourcing them. RV stuff maybe?
Jump This said:You could probably get away with a steet car hood scoop also.
But don't dump the side exit idea without some thaught. It wouldn't need to exstend beyond the body panels and you could even recess it a bit....
Rick
Goatman said:But it would have to go under the frame rail, which wouldn't work on the trail. I tried for one trip exiting right behind the muffler with a turned down pipe, but on the trail it kicked up so much dust that it was a real PIA.
Jump This said:This problem will go into my "Deep Thought" file....someday I'll come up with a neat solution.
Rick
When was the last time you were in the dirt anyway? Rocks yes....dirt?
Jump This said:Another idea.
There is no reason not to cut a hole through the frame rails as long as you weld in a tube to regain the structural integrity of the rail. Look how your stock gas filler line goes through the rail. After this hole is cut and supported run the exhaust out that way.
I just might do that to my rig....
Rick
But don't dump the side exit idea without some thought. It wouldn't need to extend beyond the body panels and you could even recess it a bit....
Rick
