-96JeepSpeed-
- Tweaker Valley CA. (Spring Valley)
8.25s have bigger axel tubes then a XJ 44, but i belive there not as thick.
For clarification to the OP:
Front axle is a Hi-pinion Dana 30
I've actually heard that the 8.25 is just about as good as it gets from the factory. I think the reason people like the d44s, is cause there are more locker kits for them, and they're easier to find.
(just as a disclaimer, I THINK this is correct. If someone knows better, please set me straight)
Cool just for shits and giggles I'll pop the cover off tomorrow and count the splines. Hope I have the 29!!
How do you know an HP vs. LP?
I'm not sure that you can tell without pulling the axle out...
My LATE 96 has the 29 spl. so like mentioned... so there's a chance it's a 29 spl.
4.56 gears are as deep as you can go... the avle is a C-clip set up... I'm happy with mine on 32s with a power tracs locker...
If you keep it you can find some 29 spl. axles if you don't have them now...
Curt
So If I pull the cover off, I wont be able to tell if its 29 or 27?
The pinion enters the axle above centerline. If it was a low-pinion D30, the casting would look different and would be relatively flat across the bottom. This one shows a definitive lip behind the 'pumpkin' where the gears are (where the 60-7AF casting is).How do you know an HP vs. LP?
Just wanted to show this shot again - beautiful shot of the C8.25 showing the lip around the cover, and the casting on the lower corners. However...WTF is up with that glob o'goo where the breather tube comes out??
