danny boy
- Pacific Beach, Ca.
Hey all,
This comanche is driving me insane. First off, 1989 4.0 manual.
This began when it drove to work fine (3 months ago!) and then about 100 yards after leaving on the way home it starts to sputter and die. It would start but as soon as you tried to move it would die. I pushed it back to work lot and it sat.
I recently tried a temporary hard wire of fuel pump in order to test. I jumped it and it started but wouldn't idle or accept more throttle. Then swapped out CPS.
Yesterday I checked and found the center contact in the dist. cap was missing. Replaced cap and rotor so I got spark against the block. Plugs very sooty black. Used a jumper wire to bypass fuel relay and got fuel at the schraeder valve. SO.... I've go spark and fuel, but no fire. What the heck? I'm now wondering if whatever tells the injectors to squirt isn't doing so.
What is going on with this thing?
p.s. it has orange ford injectors and a tps from an automatic. I tested MAP sensor and it is good.
HELP!
Dan
HELP!
Dan
