In process of modifying a harness and am looking for the OEM terminals for the mini relays and both max/mini fuse banks.
Have seen folks reference part number 5014460AC. Which is called a PDC repair kit. Problem is that these terminals already have a short length of wire factory crimped to the terminal itself. Not the idea way to go when you want to power, say a fuel pump and the input/output for the relay (30/87) is a 16 gauge wire.
Even the factory PDC wiring is less then what I desire for some circuits. Have considered getting several PDC`s to strip the wires and terminals from but am still faced with the same wire size limitations.
Just want the factory terminals and then I can add my own size AWG to them.
Thanks
Thanks
