JeepCherokeeGuy99
- New Bern, NC
Windshield battery and brakes.
have you checked the power cable from the battery to the PCM? corroded?
If you mean the relatively heavy gauge wire going from the batt to the power distribution center under the hood on the passenger side it looks fine but I'll take it off and clean it.
So I caved and started throwing money at the problem. Got a new CPS and used ECM. Both are non-returnable (unless they're bad) so if they don't fix the problem, at least I'll have some spares!
Sat for approx four or five years. Gas is pretty stale. Just drained it into a container and picked up a new fuel pump and strainers. Should have it running in a couple hours. It's a salvage title vehicle so I'm going to use it as a donor for my comanche project.
