hombremosqa
- West Valley City, UT
took the seats out of my xj yesterday and found out that the front seats rear inside flange bolts are coated with oil. an inspection of the underside revealed oil spray all over the underside of the trans and body. the carpet around the flange is coated with oil. was there any cover for this bolt, or what should i do?
its getting annoying smelling oil when i drive long distances.
2.) as im looking for the oil spray i noticed that the transmission mounting pad is really, REALLY REALLY soft. i want to replace the pad with a polyurethane mount. what i know i should do is fix the oil leak and replace the pad, but for now, i want to just fix the pad with something NOW. will the Polyurethane pad hold up to oil?
HELPHELPHELPHELPHELPHELPHELPHELPHELPHELPHELPHELPHELPHELPHELPHEP!!!!!!!!!!
