LBEXJ
NAXJA Member #721
- Parke County, Indiana
I have picked up everthing I (think) I need to replace these seals. Having a good time . The bolt is being very stubborn. I tried clamping the T60 torx socket in a pair of Vicegrips, but they just slipped around the socket no matter how tight I clamped them (not enough room between the adaptor and frame rail to use a breaker bar or ratchet). Tried grinding a flat spot on adjacent sides, but they continued to slip. So now, I have sacrificed an 11/16" wrench and welded the socket to the box end ... cut the open end off to facilitate sliding a cheater over the end. I am waiting for the wrench to cool off before trying to get the bolt loose from the adaptor.
:rof: :rof: Les
:rof: :rof: Les
