rpholz
- Jacksonville, FL
there is a allen screw in a housing off the throttle body that pushes against the throttle lever that someone before me had adjusted.
I had one that had been tampered with, but it didn't seem to make much difference. As it happened, my throttle body was badly worn anyway, so I solved the problem by replacing it. I'd leave it alone, since there seem to be no instructions on how to "un-tamper" it.
well ive gotten it pretty close but it idles at 1300 at start up and wants to slowly climb drivability isnt too bad but definatly not right
Has anyone tampered with the idle air screw that has a Torx head on the driver's side of the throttle body?
If it is slowly climbing, that sounds like it may be an intake manifold leak getting larger as the engine warms up, loose bolts on the intake/exhaust manifolds.
Is it backed out all the way and then turned in until the SLIGHTEST movement is seen in the butterfly?
ok so i said screw my poor eyesight and did the idle screw by feel looks alot closer now and has the TINIEST gap idle is down low now and not climbing will reset tps again and see what happens. also part time light is on and even with a new t-case switch will not turn off
