tantotrailers
- IL
Any of you using an OBD2 adapter to keep track of coolant temps? If so, what's the temp range that you see when she's all warmed up and pushed to the max (sitting in traffic, AC on, 90+ out)?
Mine fluctuates from 194-226 (max since replacing fan clutch is 232 but that was only once) most of the time it's at 210 or less but creeps up to 222-226 at stoplights in 95*F and direct sunshine on the hood. Nothing modified on the cooling side. New 195* thermostat, temp sensor, and radiator recently flushed. My dashboard gauge moves from the 2 in 210 to the 0 but doesn't really show the actual temp when it's at 222...if anyone were to look at it they would say it's 212...but the OBD2 output says different.
At what temp does the electric fan kick on?
Sent from my iPad using Tapatalk
