National Drivetrain
- IL. CA. Ga.
I swapped a t-case and live front end under the Cherokee 2 years ago for the Baja 500.
I had to swap the planetary to the smaller spline to match the trans I got from a junk yard.
While putting it all back together I noticed it was able to go into 2WD low and 4WD low. (I didnt know they could do that...)
Anyway, everything was hunky dory during the 500 but with the stock Cherokee shifter it would pop out of 4WD every once in a while.
To cure the problem that I thought may be the unabody playing games I ordered a Novac shifter that mounts to the t-case and not the body.
I cant honestly say that 4WD low ever worked again, but I'm not sure. It doesnt get put into low very often.
I've played with the linkage ect.
I took the linkage off and shifted it by hand with the tire off the ground and can not get it into 4 low. But I've got 2 low all day long...
Any clues?
Bent mode fork??
Thanks,
Eric
Any clues?
Bent mode fork??
Thanks,
Eric
