- Salem, OR
Pulled these offof a zj at the junk yard, now I know the front suspension is the same/similar to the xj which is why I pulled them, but looking up tuff country I can't tell if they are for the 2" or 3.5" lifts, since there are two 2" lift kits(ez-ride/ez-flex) and two 3.5"(ditto) I've compared them to other xj LCA and they look to be the same length but I don't know if that warrants them being the 2" arms since I think some 3"-3.5" arms are indeed the same length as stock.
Edit: never mind, comparing pics this is the 3.5" lift.
New question then, should I Rock them? I'm sticking with 31" till I can swap my other axle in and I'm at 3" lift. Plus is their bushings only able to get then from them or are they more widely used bushings?
