hey all, haven't been on here in quite a while as my xj has just been rocking along great. It is a 1990 with 4l and AW4 auto. Heavily modded running gear but engine managemetn is pretty much stock. I am running a 2 battery system with both batteries in parallel with no isolator (for now). hey, it's only temporary until it becomes permanent, right? :rof:
Last time I drove it was about a month ago, came home and parked it. Went to start it yesterday and nothing happens when I turn the key - as in no clicks, whirrs, pops or anything.
battery voltage is good and I even topped them up on the charger. With the key off, I have power locks, headlights and dome lights. That is it for electrical accessories.
Key on, I have nothing more - no wipers, no blower motor.
My dual electric fans are wired directly to the battery through relays and I have manual switches inside - they work fine and strong.
I have the starter relay by the battery and I put 12v to the starter wire and got cranking so the starter solenoid and starter motor are not suspect.
So probably the NSS or ignition switch - any thoughts on which one would interrupt power to accessories as well as the starter? Seems to me the NSS would only concern itself with the actual starting circuit and shouldn't affect wipers and blower motor?
leads me to suspect the ignition switch more.
Just tossing it out there for any ideas before I really dig into it tomm night.
