joe_peters
- Grants Pass, OryGun
Ok.
12 volt to positive primary side of coil, trigger ground from PCM to negative primary side of coil--it will either fire if the coil is good or not fire if the coil is bad.
You have confirmed 12 volts to the positive primary side of the coil. Determine if the triggering negative is being sent from the PCM and if its reaching the negative primary side of the coil.
