mike71800b
- US
The regulator for the fuel rail responds to changes in vacume when you change thorottle positions. I.E. it raises fuel pressure when you floor it. I don't think it would be bad.
mike71800b said:Don't jump across the resistor, you may burn up the pump. Check the voltage across it, if it is burnt open it will have the full batery voltage b/t the terminals of the resistor. If it checks less than full voltage on its terminals then it is doing its job and there is a load on the pump end.
If you want to learn more D.C. tricks in this manner, google voltage drop in series circuits and read a while.
It's ok to jumper the relay to see if it has bad contacts or isn't being relayed on by the ecu.
8Mud said:I'd say it's about fifty-fifty, the guys that have swapped out the pump and fixed the problem and those who have swapped out the pump and then had to find the original problem.
When you turn the key to run, the fuel pump relay will close for a second or two (if you hold your finger on the relay you can feel it click), just as a prime, it doesn't really build much pressure. It builds enough pressure to get just a slight squirt if you depress the shradder valve. During start, the fuel pump relay closes and supplies power to the ballast resistor relay (the ECU closes the relay), which bypasses the ballast resistor for the start, then you get pressure. If the ballast resisitor is bad, it will start (likely) but won't run and will shut down as soon as you release the key. The ballast resisitor is bypassed (through the ballast resistor relay) when the key is in the start positon.
The dark green and black wire at the resistor, is the pump end of the resistor and should have power, for a second or two, when the key is turned to run and during start and with the key in the run posiston after the motor is running.
If the fuel pump relay isn't actuating, it's usually because the ECU refuses to actuate the relay, bad CPS, bad Cam posiiton sensor, maybe the MAP is getting no mean atmopheric pressure index signal and other stuff.
There is also the off chance that a connector is corroded (no power to the pump), a relay is flacky or the pickup tube on the pump is falling apart and there is a hole in it.
Or maybe a bad pump. Changing out a pump is a beatch. I'd sure as heck make sure I'm getting juice, before I went through the convulsions of changing one.
I've had fuel problems on three different XJ's (sometimes multiple problems with different causes, at different times) and haven't replaced a pump yet. It always turned out to be something else.
gundog said:What exactly will jumping this do?
jordo said:Bypassing the resistor will send more juice to the pump. The resistor simply reduces the voltage to the pump so it's not so noisy when it operates. The pump doesn't need to operate at full tilt to deliver the required fuel. If the resistor is failing the pump will not be recieving enough juice therefore not pumping enough fuel. However, as someone mentioned earlier make sure your wires/connections to the pump are in good condition first.
edit-whoops-looks like i missed a page and things were explained-my bad.
Flash said:I can't tell ya what colors are, they but if ya fallow the wires form the pump you will now with 2 that you need(power and ground to the pump are the one's the you need to trace back form pump to conector.............I thing it even Has (+) (-) on the pump.
Flash
