Schris1
- California
1986 2.5L throttle body injection Jeep Cherokee. The Jeep has had trouble starting in the mornings. Now it doesn't want to start at all. I have to crank it multiple times before it will even consider starting. I found that fuel isn't being sprayed during cranking The butterfly in the throttle body is completely dry. If I spray some carb cleaner in the throttle body, it will start right away. Once it's started, it runs fine. It does have trouble starting at other times through out the day. I checked the fuel pressure and it's reading fine (15-17 psi). I am thinking that the injector is bad, but I want to know for sure before I speed the money for it. Any ideas?
