jphoto
- Chatham, Il.
Ok I searched.
It's not a vaccum actuated d30. I put the jeep on jack stands today and put it into 4 wheel high. The rear tires both spin..... limited slip? but the front drive shaft isn't spinning so the tires aren't moving and the part-time light does not come on.
If I try to put it into 4-low it pops out of gear and the transfer case won't shift if the transmission is in neutral it sounds like everything is still moving and grinds if I try to put the x-case in high or low 4-wheel-drive with the transmission in neutral. I can only get into 4-high with the transmission in park.
I was hoping it was just a linkage issue but now that the front drive shaft isn't spinning I'm thinking it might be worse.
Any help is appreciated, thanks.
