wim hoppenbrouwers
- Netherlands europe
5-90 said:Make sure you have power to Pin 30 - should be constantly hot.
I don't recall which way the coil of the relay is wired - check. With the coil out, check continuity between Pin 85 & ground, and Pin 86 & ground. One will have continuity, the other should have +12V with the key in the START position.
If both of those check out, replace the relay. Should be a standard DIN/ISO relay, available anywhere for around ten bucks.
Hallo. A question for understanding please. The pin 86 or 85 is one of them going to the NSS? So if I jumped from pin 85 to ground, the NSS is bypassed and the jeep will start in any gear? So you can test the NSS very easy.
thamks and gr.:huh:
