1991Jeep_Man
- ShenCo
I'm actually nervous about posting this in the first place due to the possibility of an all out oil war, but here it goes.
My '91 XJ has about 210k miles on her. Everything thus far has been kept up to date and taken care of. No leaks, no overheating, coolant change, oil change (mobil 1 High Mileage 10w30 for the longest time), etc. Now, with my recent oil change I used Mobil 1 High Mileage 10w40 rather than 10w30. Honestly, I was surprised by the results. My oil pressure, while never really low or anything, seemed more stabil and slightly higher, and when the engine reached op temp, some of the little noises I used to have seemed to either lessen or go away completely. Loved it. However, I am more concerned now because after reading many oil articles and what not, cold startup is the biggest wear and tear moment on an engine. And I will be honest, both the 10w30 and 40 had their share of cold start noises. My solution? I want to run a good 5w40, especially with colder weather among us here in Shenco. Now, this is where I will say I am not looking for an oil war or flame debate. I have basically narrowed my choice for oil down to two oils:
Mobil 1 Turbo Diesel 5w40, or Shell Rotella T6 5w40.
Which would you all suggest? From I've heard and researched, both oils are good, and many people run diesel oil in their 4.0's (although, I must admit I dont agree with those who swear by 15w40 and 20w50). So which oil do ya'll think I should go with? Btw, I currently use a Mopar oil filter. I know PureOne filters are supposed to be the best, but I actually had one of their filters suffer an internal failure and reduce my oil pressure rather drastically. New filter solved the problem, and Puralator determined their filter did in fact fail. If anyone has a good suggestion for an oil filter for these oils, please chime in! Thanks everyone.
