I need to convert my rear xj dana 44 to a six lug because i just picked up a waggy 44 for the front. I can't seem to find any wheel adapters to go from a 5 to 6 lug
It'd be "safer" to get your shafts redrilled if there's enough material on the flange. But it'd be easier to just to get the adapters because aside from having you redrill your shafts, you'd have to redrill your drums/rotors too.
If you do some searching you should find that those adapters don't work due to the hole for the hub not being large enough for a front axle. The easiest way to get matching in all 4 is to put a waggy rear axle or a izuzu rear d44 axle.
