ncgamedog
- Charlotte, NC/ UNCC
I am about to pick up a super super nice 91 MJ. it has a new 4.0L HO crate engine, zero rust and TJ buckets ect. Here is the kicker! its 2wd. I feel like its worth it, but want to be sure. It has a 2wd ax-15 and 35 rear. What do I need to do to make it a stock type 4x4???? i know I will need the obvious parts, 231, 30 front, drive shafts, and new cross member. Anything else? I mainly want to find out if it is possible to remove the 2wd tail shaft from the ax-15 and bolt the t-case up w/ no mods? Is this possible, or will I need a whole new tranny?
thanks for any light you can shed! -J
