winkosmosis
- Maui, Hawaii
Well I cleaned as much as I could with Simple Green and paper towels (no degreaser and hosing down yet) and drove to the beach... no fresh oil yet. It must be a really slow leak.
EXACTLY. It always seems to drip off the lowest part of the engine at the rear...
I don't think it has a choice what with gravity and all.
Looks like your valve cover may have a "seep" in that area but not enough to create drops. If the VC is to blame it's likely be AT the rear (the part you can't see) as it's a.) out of sight and b.) the hardest bolt to tighten.
Keep looking
I'm not sure you can get a filter in or out with no OFA and the frame rail where it is.OK, I've confirmed that it's the oil filter adapter that's leaking. Not looking forward to getting that damn torx bolt out.
Is the elbow adapter really necessary? Why not screw the filter into the engine block directly?
