2000xj4x4
- mandeville,La
2000xj4x4 said:yea i could but i mounted the tank a little to close to the hatch so it doesnt fit to well but the tank has six ports so i can always put it somewhere else.
You can easily do that with a pressure switch that automatically shuts the compressor off at a pre-set pressure and it will kick on again when the pressure drops to another pre-set pressure. This is very common on OBA setups that run air lockers. I've got more info about that type of setup here: http://www.ericsxj.com/oba.htmbigolexj said:Question: Does this OBA kit run air tools well? Does have an auto-recycle feature? I mean, do you have to run the compressor manually when the tank empties or gets too low or does the compressor cut on automagically?
I've been looking for a compressor that will do that for a long time and no one seems to have any answers, so I've stuck with Nitrogen and CO2.
