_MURDERED OUT_
- Hernando, MS
yep.
There really isn't a way to get a decent length on the trackbar with rockwells huh? Links look alot more level with the vehicle's weight on it. Looking good
Looks like it's really coming along but I have to ask what are you going to do to hold the top of those coils in place?
With the weight of a rockwell I'd have ordered alot thicker DOM for the trackbar. That's alot of weight to sling around. There's guys on the forum that've bent that with a d30.
And i went to the pull a part today and scored an xj steering shaft for $8 (i will be cutting it up to lengthen mine)and a lincoln mark eight 2-speed fan for $30. Supposedly those mark 8 fans are badass. Now i got to figure out where to get big enough amp relays to run the thing. I know with the taurus fans you have to use 10 gauge wire and heavy relay or solenoid. Any recommendations??
Good Bosch style relays go up to 30 amps, which is a lot of amps, 360+ watts. You could also run two in parallel. Thats a pretty heavy load on an alternator.
This rig is going to be badass if it doesn't fold like a taco !!!1
isnt your trackbar(before you decided to relocate) a "panhard" bar if its opposite the draglink?
