NorCalChris
- Central Coast, Ca
Basically a 4.6 low buck stroker option 1
- 96+ 4.0 block (casting # 53020569)
- 91-95 4.0 ported head (casting # 7120)
- 72-80 4.2l Crankshaft (casting #3214723) machining 1cm off the nose
- 4.2l rods shot peened and balanced (707 casting?)
- mopar performance head gasket (0.043)
- Clevite bearings (cam, main, rod)
- balanced Speed Pro h825cp pistons + 0.030"
- Hastings piston rings
- camshaft has yet to be determined. I still need to plug the numbers in on the computer (what are you running?)
- valve springs TBD after cam
- Yella Terra 1.6 roller rockers
- any pushrod recommendations?
- Mopar Performance High volume oil pump #P4529241
- Pioneer freeze plugs
- I haven't decided on hi flow water pump or not.
- 99+ intake ill grind some of the casting marks away.
- bored throttle body (any comments on Leigh Performance Machine? recently Ive heard good things about them.)
- cold air intake (thinking about moving filter into the cowl) and keeping the stock set up for smog, unless I can find a CARB legal intake of my liking)
- Ford injectors with a hesco regulator (anyone ever use Leighs machine's FPR?)
- Cloyes dual roller timing set
- Borla header? ( i prefer an equal length design. any recommendations on headers? keep in mind CARB legal)
- 2.25 in down tube w/ 2.5 cat and spin tech muffler.
- MSD 6AL ignition box w/ rev limiter, blaster coil, wires.
